Last Firmware upgrade available
diego_cianet
diego_cianet Posts: 2 image  Freshman Member
edited August 2022 in Switch
Hello. I know it is an old device, but still works and I plan to build a small network with it. Where can I find the last firmware upgrade available for the switch model MES-3528?
Here is the output of the "MES-3528# show system-information"
Product Model           : MES-3528
System Name             : MES-3528
System Contact          :
System Location         :
System up Time          :     0:02:28 (3ab7 ticks)
Ethernet Address        : cc:5d:4e:3c:XX:XX
Bootbase Version        : V1.05 | 02/19/2009
ZyNOS F/W Version       : V3.90(BHR.5)20130312 | 03/12/2013
RomRasSize              : 2404122
    PeterUK Posts: 4,447 image  Guru Member
    edited April 2021 Answer ✓
  • diego_cianet
    Thank you for your fast response. Do you recommend upgrade with both files, BHR.4 and then BHR.5?
    Or should I upgrade only with the last one (BHR.5) ? Thanks again
    I would think the BHR.5
  • ispindel
    ispindel Posts: 1 image  Freshman Member
    Despite clicking the link and putting my username in, I can't seem to connect to the FTP. Can I just double check, im running V3.90(BHR.5) | 06/10/2011 on my MES-3528. Is this the latest version according to the FTP files?
  • mMontana
    mMontana Posts: 1,469 image  Guru Member
    I used third party App as FTP client (not anymore included into some browser) and i found files... Without username/passoword
