Why does my new USG 60 only allow half internet speed
Blueprint
Blueprint Posts: 2 image  Freshman Member
edited April 2021 in Security
Recently after no changes made to my firewall, my lan speed has dropped from 1Gb up/down to 250Mb up/down. No changes to network. We experienced a brief lan outage that came back after 5 minutes. Since that outage the slow speeds are all we see.
Direct connect to router shows 1Gb up/down.
Tried many things, Last was hardware reset the USG 60, still slow.
If I turn firewall off from easy screen, speeds bump up to 450Mb up/down.
Unit is 3 months old, It appears to me to be a hardware issue internal to the USG60
Prior to the above mentioned lan bump all was working as expected.
Any insight to this is appreciated.
