USG60 Wishing to block an IP Range - How to?
Blobby123
Blobby123 Posts: 3 image  Freshman Member
First Anniversary
Hiya, I woiuld like to block a range of external IP's from attemping to access the server within the network.
I have tried to add the range to the Object - Geo-ip section but the IP rage is still getting through.
Any help appreciated! :)
    edited April 2021
    Content Filter needs to be activated for Geo-ip to work.
    On the Address click add
    name = name
    address type = GEOGRAPHY
    region = select one
    Then go to security policy > policy control add
    name = name
    from = WAN
    To = LAN1?
    Source = your above Geo-ip object
    action = deny
  • Blobby123
    First Anniversary
    Thank for that.
    I believe we subscribe to content filter?
    In fact to:
    Anti-Spam
    Gateway Anti-Virus_Bitdefender Signature
    Content Filter
    IDP
    SecuReporter Premium
    Could it not be activated?
    In Licensing > Registration > service tab does it say "Activated" for Content Filter 2.0?
    Have you updated the Country Database in Geo IP
  • Blobby123
    First Anniversary
    Hi, Yes, all 5 are actviated.The country database is up to date and set to autoupdate.
    It was the IP range I set in the section 'Custom IPv4 to Geography Rules' that did not seem to work.
  • Zyxel_Can
    Zyxel_Can Posts: 342 image  Zyxel Employee
    25 Answers First Comment Friend Collector
    Hi @Blobby123,
    Did you try to create Address range object and assign it to a Security Policy rule?
    1- Create address range object (Configuration > Object > Address/Geo IP)
    2- Assign it to a Security Policy rule (Configuration > Security Policy > Policy Control)
    Also, please make sure Policy Control is enabled (Configuration > Security Policy > Policy Control)
