SFP Port USG Flex 500
1Gbps is the maximum speed of the SFP port. Zyxel is very flexible on the SFP and SFP+ modules you can use in the USG Flex 500 and various switches, specifically this and the XS1930s and the XS3800. We have tested new G10tek and used Cisco in the above with no problems, including a 1Gbps copper SFP. Many others should also work. Don't forget that the USG Flex 500 and above support LAG to combine ports together which is supported by many switches and some modems and gateways.0
Hi dkyeagerdkyeager said:1Gbps is the maximum speed of the SFP port. Zyxel is very flexible on the SFP and SFP+ modules you can use in the USG Flex 500 and various switches, specifically this and the XS1930s and the XS3800. We have tested new G10tek and used Cisco in the above with no problems, including a 1Gbps copper SFP. Many others should also work. Don't forget that the USG Flex 500 and above support LAG to combine ports together which is supported by many switches and some modems and gateways.The port is then a sfp and not a sfp+ port if it can't runs at 10G when you use the new 10G sfp+ it only runs with 1G in USG Flex 500 if I understand you rightClaus0
In our office, using sfp interface achieved up to around 800Mbps. FYR0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
