Issue cannot acces to wifi Zyxel usg20w-vpn
JosephByTangier
Wifi zyxel not appear, i have no access, i have download firmware to flash device usb, but it's not working too, plz i need help to flash device with a new firmware.
You can't update the firmware by USB to the USG only from a PC.
If you can't access the USG logon you need to reset and re-setup the USG
Thank you for your response.
I reset a several time but still no access to USG logon0 -
Hi @JosephByTangier
Can you get the IP address from the USG20W-VPN correctly? If so, can you ping to the device IP address successful as well?0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
