Issue cannot acces to wifi Zyxel usg20w-vpn
JosephByTangier
JosephByTangier Posts: 2 image  Freshman Member
edited April 2021 in Security
Wifi zyxel not appear, i have no access, i have download firmware to flash device usb, but it's not working too, plz i need help to flash device with a new firmware.
    PeterUK Posts: 4,446 image  Guru Member
    You can't update the firmware by USB to the USG only from a PC.
    If you can't access the USG logon you need to reset and re-setup the USG
  • JosephByTangier
    Thank you for your response.
    I reset a several time but still no access to USG logon
  • Zyxel_Vic
    Zyxel_Vic Posts: 323 image  Zyxel Employee
    25 Answers First Comment Friend Collector Eighth Anniversary
    Hi @JosephByTangier
    Can you get the IP address from the USG20W-VPN correctly? If so, can you ping to the device IP address successful as well?
