Zywall 110 Not allowing VPN connections
I have a Zyxel Zywall 110 and I have set up a VPN connection using the quick wizard.
However, the downloaded .bat file and the .ps1 do not make the connection from a windows 10 system.
I get the error message:
A connection to the remote computer could not be established, so the port used for this connection was closed.
I have watched all the videos that say I should delete the wan network adaptors and rescan. Googled the error message, searched the forums, That didn't work.
I could really use help in a big way. The problem has been going on for a week and no one out of the office can connect.
Please assist.
As I said, "I have watched all the videos that say I should delete the wan network adaptors and rescan. Googled the error message, searched the forums, That didn't work."0
Testing here with my Zywall 110 on V4.62 on a Pre-Shared Key VPN setup with win10 all is fine.
Check firewall you have:
like from WAN to ZyWALL
from IPSec_VPN to ZyWALL
with service
ESP
IKE
L2TP-USP
NATT
Check you have phase 1 proposal as:
3DES- SHA1
AES128 – SHA1
Phase 2 proposal as:
AES256 – SHA1
3DES - SHA1
Can you post your settings for VPN gateway and VPN connection.
Hi @baparks,
Can you delete your old VPN connection that created by scripts(.bat or ps1) then create your Windows client’s L2TP VPN manually?
(Windows Start > Settings > VPN > Add a VPN connection)
Control Panel\All Control Panel Items\Network Connections > ZyWALL110 > Properties > Security
That was the ticket. Thanks. I have been struggling with this for a while.1
- 601 USG FLEX H Series
- 480 News and Release
