Syntax for Exclude List in SSL Inspection
Best Answers
Hi @Motivio,
\* used for one wildcard character.
* used for multiple wildcard characters.
"\*.adobecces.com" = Adding this entry in the exclude list will exclude only the hosts with one character under adobecces.com domain.
"*.adobecces.com" = Adding this entry in the exclude list will exclude all the hosts under adobeecces.com domain.
Here’s the reference link which you can read more about;
http://webhelp.zyxel.com/search.action?model=USG%20FLEX%20200&majVer=V5.00&minVer=&fwID=ABUI&lang=EN&hash=context/Help/SecurityService_SSLInspection_ExcludeList&help_version=2
Thanks, found it: "Use ‘\*’ to indicate a single wildcard character."0
Hi @Motivio,
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
