usg60W - MAC has blocked by prev-Auth Failed on Channel
Hi Community,
Since a few months, my wifi devices are disconnected untimely from my local AP.
Below and as an attachment, the log for station: 60:6c:66:d6:b2:f8.
The logs do not allow me to find the problem and I do not take what is happening.
Thanks for your help
Wireless LAN
Station: 60:6c:66:d6:b2:f8 has blocked by Hostapd3 on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz. reason 1, Interface:wlan-1-1 [count=4]
Wireless LAN
Station: 60:6c:66:d6:b2:f8 has blocked by prev-Auth Failed on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz. reason 2, Interface:wlan-1-1 [count=4]
Wireless LAN
Station: 60:6c:66:d6:b2:f8 has deauth on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz, Tx/Rx: 0/0 Bytes. reason 1, flags=0x3, Interface:wlan-1-1 [count=4]
Wireless LAN
WPA authenticator requests disconnect: reason 1. Interface:wlan-1-1 Station: 60:6C:66:D6:B2:F8 [count=4]
Wireless LAN
Station: 60:6c:66:d6:b2:f8 has deauth on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz, Tx/Rx: 0/0 Bytes. reason 2, flags=0x3, Interface:wlan-1-1 [count=4]
Wireless LAN
WPA authenticator requests disconnect: reason 2. Interface:wlan-1-1 Station: 60:6C:66:D6:B2:F8 [count=4]
Wireless LAN
Station: 60:6c:66:d6:b2:f8 has associated on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz. Interface:wlan-1-1 [count=6]
Wlan Station Info
STA Disassociation(1:UNSPECIFIED) by STA Logout. MAC:60:6C:66:D6:B2:F8, AP:Local-AP, interface:wlan-1-1, SSID:BBOX_FIBRE, Tx/Rx:0/0 Bytes, session time:0H:00M:06S
Wireless LAN
Station: 60:6c:66:d6:b2:f8 has deauth by STA Logout on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz, Tx/Rx: 0/0 Bytes. reason 1, Interface:wlan-1-1
Wlan Station Info
STA Disassociation(8:DISASSOC_STA_HAS_LEFT) by Duplicated Auth. MAC:60:6C:66:D6:B2:F8, AP:Local-AP, interface:wlan-1-1, SSID:BBOX_FIBRE, Tx/Rx:7580/10267 Bytes, session time:0H:00M:44S
Wlan Station Info
STA Disassociation(8:DISASSOC_STA_HAS_LEFT) by Duplicated Auth. MAC:60:6C:66:D6:B2:F8, AP:Local-AP, interface:wlan-1-1, SSID:BBOX_FIBRE, Tx/Rx:0/0 Bytes, session time:0H:00M:11S
Wireless LAN
Station: 60:6c:66:d6:b2:f8 has disassoc by Duplicated Auth on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz, Tx/Rx: 0/0 Bytes. reason 8, Interface:wlan-1-1 [count=3]
Wlan Station Info
STA Disassociation(8:DISASSOC_STA_HAS_LEFT) by Duplicated Auth. MAC:60:6C:66:D6:B2:F8, AP:Local-AP, interface:wlan-1-1, SSID:BBOX_FIBRE, Tx/Rx:3665/11618 Bytes, session time:0H:00M:25S
DHCP
DHCP server assigned 192.168.2.20 to (60:6C:66:D6:B2:F8) [count=4]
DHCP
Requested 192.168.2.20 from (60:6C:66:D6:B2:F8) [count=4]
Wlan Station Info
STA Association. MAC:60:6C:66:D6:B2:F8, AP:Local-AP, SSID:BBOX_FIBRE [count=4]
Wireless LAN
Station: 60:6c:66:d6:b2:f8 has authorized on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz. Interface:wlan-1-1 [count=4]
Wlan Station Info
STA: 60:6c:66:d6:b2:f8 has blocked by Hostapd3 on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz. reason 1, Interface:wlan-1-1. [count=5]
Wlan Station Info
STA: 60:6c:66:d6:b2:f8 has blocked by prev-Auth Failed on Channel: 11, SSID: BBOX_FIBRE, 2.4GHz. reason 2, Interface:wlan-1-1. [count=4]
Hi @Didierfon
It means the authentication is not successful. It might be caused packet lost or radius no response during the authentication process.
There are only 2.4GHz using channel 11 in the logs. Usually, radio 2.4GHz is shared with other non-Wi-Fi signal and only has 3 non-overlapping channels which may generate interference.
We suggest to setup an SSID services in radio 5GHz to have better performance if the clients have capability using 5GHz.
Regards,
Bella
Hi Bella,I don't have a radius and probably this dysfunction is related to interference.Unfortunately, the devices in question do not support 5Ghz and the ether is very crowded and it is difficult to find a better channel :-( but I will try anyway.
Thanks for your answer.
Didier0 -
Hi @Didierfon,
Thanks for your feedback.
You can also use DCS to let AP auto select better channel to provide service.
Or use signal analysis tool like inSSIDer to scan the environment then choose a less-used channel.
Hope it can help you resolve the problem.
Regards,
Bella
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
