Help with vlan trunk migration: Huawei -> Zyxel GS2210
DTI
DTI Posts: 2 image  Freshman Member
Friend Collector
edited August 2022 in Switch
Hi!
I'm new on Zyxel world and its is harder to understand the vlan conf.
I need to create vlan trunk, but can't do with zyxel.
Anyone can help with migration from huawei conf to zyxel?
Huawei:
interface Vlanif50 ip address 172.16.50.1 255.255.255.0
interface GigabitEthernet0/0/1-15, 17-24 port link-type hybrid port hybrid pvid vlan 16 port hybrid tagged vlan 1001 port hybrid untagged vlan 16
interface GigabitEthernet0/0/16 port link-type trunk port trunk pvid vlan 50 port trunk allow-pass vlan 10 16 50
interface GigabitEthernet0/0/25 port link-type trunk port trunk pvid vlan 8 port trunk allow-pass vlan 8 13 50 1001#interface GigabitEthernet0/0/26 port link-type trunk port trunk allow-pass vlan 8 50 1001#interface GigabitEthernet0/0/27 port link-type trunk port trunk allow-pass vlan 2 to 4094#interface GigabitEthernet0/0/28 port link-type trunk port trunk allow-pass vlan 2 to 4094
  • DTI
    Friend Collector
    Hi @DTI,
    Welcome to Zyxel Community.
    I help you to migrate your configuration as following:
    Please copy and paste to switch
    vlan 1
      normal 1-28
      fixed ""
      forbidden ""
      untagged ""
    exit
    vlan 8
      normal 1-24,27-28
      fixed 25-26
      forbidden ""
      untagged 25
    exit
    vlan 10
      normal 1-15,17-28
      fixed 16
      forbidden ""
      untagged ""
    exit
    vlan 13
      normal 1-24,26-28
      fixed 25
      forbidden ""
      untagged ""
    exit
    vlan 16
      normal 1-15,17-28
      fixed 16
      forbidden ""
      untagged 1-15,17-24
    exit
    vlan 50
      normal 1-15,17-24,27-28
      fixed 16,25-26
      forbidden ""
      untagged 16
      ip address default-management 172.16.50.1 255.255.255.0
    exit
    vlan 1001
      normal 16,27-28
      fixed 1-15,17-26
      forbidden ""
      untagged ""
    exit
    interface port-channel 1-15,17-24
      pvid 16
    exit
    interface port-channel 25
      pvid 8
    exit
    interface port-channel 27-28
      vlan-trunking
    exit
    Please let us know if there is any missing configuration.
    Hi, thanks to reply! I'll try this.
    You can give me some tips about vlan trunk?
    I'm confused with "normal / fixed / forbidden / tx tagging"
  • Zyxel_Adam
    Zyxel_Adam Posts: 429 image  Zyxel Employee
    Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
    edited May 2021
    Hi @DTI,
    vlan 1
      normal 1-28
      fixed ""
      forbidden ""
      untagged ""
    exit
    vlan 8
      normal 1-24,27-28
      fixed 25-26
      forbidden ""
      untagged 25
    exit
    vlan 10
      normal 1-15,17-28
      fixed 16
      forbidden ""
      untagged ""
    exit
    vlan 13
      normal 1-24,26-28
      fixed 25
      forbidden ""
      untagged ""
    exit
    vlan 16
      normal 1-15,17-28
      fixed 16
      forbidden ""
      untagged 1-15,17-24
    exit
    vlan 50
      fixed 16,25-26
      forbidden ""
      untagged 16
    exit
    vlan 1001
      normal 16,27-28
      fixed 1-15,17-26
      forbidden ""
      untagged ""
    exit
      pvid 16
    exit
      pvid 8
    exit
      vlan-trunking
    exit
    Adam
  • DTI
    Friend Collector
    Hi @DTI,
    vlan 1
      normal 1-28
      fixed ""
      forbidden ""
      untagged ""
    exit
    vlan 8
      normal 1-24,27-28
      fixed 25-26
      forbidden ""
      untagged 25
    exit
    vlan 10
      normal 1-15,17-28
      fixed 16
      forbidden ""
      untagged ""
    exit
    vlan 13
      normal 1-24,26-28
      fixed 25
      forbidden ""
      untagged ""
    exit
    vlan 16
      normal 1-15,17-28
      fixed 16
      forbidden ""
      untagged 1-15,17-24
    exit
    vlan 50
      fixed 16,25-26
      forbidden ""
      untagged 16
    exit
    vlan 1001
      normal 16,27-28
      fixed 1-15,17-26
      forbidden ""
      untagged ""
    exit
      pvid 16
    exit
      pvid 8
    exit
      vlan-trunking
    exit
  • Zyxel_Adam
    @DTI,
    Thanks for your reply.
    Kindly provide you description as below:
    For "tx tagging", selected it means tagged and unselected it means untagged for the port.
    Adam
