[NEBULA] Why can't I see my non-nebula device in Topology?
Hi, it's me again with more questions lol.
I have a Zyxel GS2200 switch that connects to three of my NAP, and my gateway is a USG 200. But it seems that the topology only tells me the Nebula devices, what about the non-nebula devices? Any place to configure or setup?
"You will never walk along"
Hi RUnglaube
The topology will show your non-nebula devices with a diamond shape (other), as explained within the symbology legend. However, the protocol LLDP is used to create this topology, then you need to be sure that your non-nebula devices are correctly configured to communicate using LLDP packets.5
Hi RUnglaube
The topology will show your non-nebula devices with a diamond shape (other), as explained within the symbology legend. However, the protocol LLDP is used to create this topology, then you need to be sure that your non-nebula devices are correctly configured to communicate using LLDP packets.5 -
What kind of information can I obtain in the topology chart by enabling the LLDP protocol on my non-nebula devices?"You will never walk along"0
Hi RUnglaube
If you enable the LLDP protocol on the non-nebula devices, you can get the MAC address in the topology.1 -
Thanks! one last question, if I have Nebula devices that are registered in different sites, will I be able to see them in the topology?"You will never walk along"0
Hi RUnglaube,
Yes, you will see Nebula devices which are registered in different sites in the topology, and it will show with a diamond shape.0 -
Thanks Irene! Everything clear now"You will never walk along"1
- 431 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 6K Security
- 385 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
