Help I am Unable To Assign Management IP On 4600 Switch Because It is on SVI and DHCP
businessuer
Posts: 134 Ally Member
in Nebula
I have a 4600 switch in which Basic setting > ip setup> is 10.2.0.1 /24.
It is assigned to vlan 2.
I want to use 10.2.0.1 for management purpose.
I can ping in from my network but when I put the ip address in web browser I cannot go in.
I try to put another ip address 10.2.0.250 as ip address also vlan 2. but it doesnt work.
The error message is Error: There must be at least one iface associated with this VID for DHCP settings.
I try put 10.2.0.250 as loopback address. It doesnt allow me to. How to solve this problem?
Summary:
Created 10.2.0.1/24 (vlan 2) SVI and DHCP for management.
Can ping 10.2.0.1. Use web browser go in cannot.
Creation of 10.2.0.2 as loopback address or new ip interface fails.
Now need Zyxel help.!!
Pls help me!
Summary:
Pls help me!
Hi @businessuer
Thanks for the information.
From you description, we can only see that you've configured a VLAN 2 with 10.2.0.1/24 subnet.
There are steps for you to confirm VLAN and DHCP settings:- Created VLAN 2 with subnet 10.2.0.1/24
- Fixed and untagged a port(s) for PC. (You may need to tagged a port(s) for your server)
- Set PVID 2 for the port, which the switchport you connected to your PC.
- Configure DHCP with VLAN 2 and subnet range as 10.2.0.0/24.
May you also share a screenshot of the error message" There must be at least one iface associated with this VID for DHCP settings" because I am unable to reproduce the issue.
For loopback interface issue, you may try to ssh/telnet/console to switch and type command as workaround now. The loopback interface can be only added by using command, and modify IP address on web GUI, I will report your issue to our engineer.
Adding Loopback interface command as below:
interface loopback (0-7)
ip address 10.2.0.2 255.255.255.0
Sorry for the inconvenience and let me know the result of VLAN&DHCP issue.
Adam0 -
Is it possible to add vlan for the loopback?0
The problem is that I am trying to ping from the wifi in the management.
I can ping the ip.
But I cannot use the web browser to go in.
So it is not vlan configuration on switch issue.
Pls advice.0 -
@businessuer,
Thanks for the update.
May you check that if the HTTP service is enabled on switch via console?
or you may check your gateway device to see if it blocks HTTP service for this switch.
Furthermore, you should not have overlapped IP subnet in a switch. 10.2.0.1/24, 10.2.0.250, and 10.2.0.2 are overlapped.Adam0 -
Dear Adam.
I am using XGS 4600.
This is the documentation: https://prodotti.zyxel.it/USERSGUIDE/XGS4600-SERIE.pdf
On pg86, it states that loopback address can be applied.
Q1 However, I want to check if it is possible to put it as vlan?
I want to purposely add overlapped subnet.
My switch is running as a DHCP Server.
The SVI is 10.2.0.1. (vlan 2)
The DHCP pool is 10.2.0.1/24.
It is giving ip addresses for a management vlan.
Using wifi I can ping 10.2.0.1.
But I cannot http or https this ip.
How do I http or https this ip?
What should i do if I cannot create overlapping subnet?
@businessuer
We are sorry for the loopback interface part.
I've reported this issue to our engineer.
Loopback interface is not allow to add VLAN.
May we know why you would like to make an overlapping subnet?
It's now possible to assign the subnet on the same switch. You should try to use another device to configure same subnet for making overlapped.
Please also check remote-management to see if http or https is allowed right IP range ,and enabled http and https on your switch.
Our switch is enabled http service by default, so it should not have problem to access web GUI of XGS4600 in your scenario.
If you are unable to access the switch web GUI after checking remote-management, you may PM the configuration of switch to me so I can help you to check.
Adam0 -
Very simple.
Switch acts as dhcp server.
I want to add 10.2.0.1 as loopback interface so I can ping it and http https in.
@businessuer,
I have to clarify that when you configured switch as:
You should be able to ping and access switch web GUI after your client gets DHCP IP address. The premise is that if your remote-management is allowing DHCP IP subnet or is 0.0.0.0-0.0.0.0 and HTTP/HTTPS.I want to add 10.2.0.1 as loopback interface so I can ping it and http https in.
Then the loopback interface 0 will appear.
Adam0 -
ok thank you. So will upgrade firmware to put vlan for loopback interface in new release?0
@businessuer,
Sorry, there is no plan to add vlan to loopback interface.
Kindly inform you that you may try to search on the Internet and see that there is no any switch and router support VLAN on loopback interface.
Kindly inform you that you may try to assign subnet for your loopback interface since 10.2.0.250 is overlapped to DHCP pool.
May we also know that if you are able to access switch web GUI now via 10.2.0.1 or IP address of loopback interface now?
Let me know if you have any question.Adam0
- 385 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 70 Switch Ideas
- 908 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 200 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 63 Security Highlight
