Zyxel AP / Can't connect Amazon ALEXA / error has deauth by STA Logout on Channel
ThierryGolo
AP Zyxel NEBULA : NWA110AX
always got this error when trying to connect my echo amazon alexa echo:
Current version: V6.20(ABTG.0)
Wireless LAN
Station: 94:3a:91:bc:6d:2a has deauth by STA Logout on Channel: 48, SSID: sspin452bis, 5GHz, Signal: -42dBm, Download/Upload: 39545/222104 Bytes. reason 3, Interface:wlan-2-2
configuration on my SSID :
Band mode
Concurrent operation(2.4GHz and 5GHz)
Layer 2 isolation OFF
Enable layer 2 isolation OFF
Intra-BSS traffic blocking OFF
Band select OFF
Assisted roaming OFF
802.11r OFF
U-APSD OFF
Hi @ThierryGolo,
Was the station disconnected from the AP after connected for a while? When the issue occurred, is there any problem for other stations, like mobile phone?
Would you share the org/site name to us and help to enable Zyxel support in HELP> Support request for us to check details of the logs.0 -
Hello, Station never connected before, it's a new material. Other stations connect very well, including my raspberry pi 3 ;-)
organisation is A1516consul
site is 2bisRueduCG
Hi @ThierryGolo,
Thanks for your information. We have collected the debug message for analyzing and will update to you asap. BTW, I checked the AP status and there's an alert for the AP's IP. After checking, the IP is set to DHCP with VLAN 1 tagged, so if the VLAN1 in your environment is untagged, please correct the configuration.0 -
Hi @ThierryGolo,
After checking the event logs in your site for the station, the disconnected reason code is 3, 8, or 34.
The reason 3 and 8 is station is leaving (or has left) BSS, so it's station's behavior to leave the AP. The reason 34 is AP kicks the station because AP didn't get station's reply or poor channel conditions. You may lower the channel width to 20MHz or 40MHz to avoid the channel interference.0
- 588 USG FLEX H Series
- 477 News and Release
