USG60 ipsec to Lan2
Hi
I have a USG60 firmware 4.62 with site to site vpn on Lan1.
I want to setup ipsec IKEV2 server to client, vpn that route traffic only to Lan2.
local policy IPSEC range is 100.100.100.1 - 100.100.100.20
I can connect, but not ping or access lan2.
/Tony
Lan1 network is 176.26.11.0
Lan2 network is 192.168.41.0local policy IPSEC range is 100.100.100.1 - 100.100.100.20
/Tony
@ITB_Tony
According to your description, you can refer to the following IKEv2 VPN configuration that can be verified successfully at our lab.
Configuration > VPN > IPsec > VPN Gateway
Configuration > VPN > IPsec > VPN Connection
Establishing IKEv2 VPN connection and navigate Monitor > VPN Monitor > IPsec > to see if IKEv2 VPN IP belongs to the LAN2 domain.
@ITB_Tony
Thx works good
, i have missed the "configuration Payload" option.
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 683 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
