USG60 ipsec to Lan2
ITB_Tony
ITB_Tony Posts: 12 image  Freshman Member
First Comment Seventh Anniversary
Hi
I have a USG60 firmware 4.62 with site to site vpn on Lan1.
I want to setup ipsec IKEV2 server to client, vpn that route traffic only to Lan2.
Lan1 network is 176.26.11.0
Lan2 network is 192.168.41.0
local policy IPSEC range is 100.100.100.1 - 100.100.100.20
I can connect, but not ping or access lan2.
/Tony
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    @ITB_Tony
    According to your description, you can refer to the following IKEv2 VPN configuration that can be verified successfully at our lab.
    Configuration > VPN > IPsec > VPN Gateway
    Configuration > VPN > IPsec > VPN Connection
    Establishing IKEv2 VPN connection and navigate Monitor > VPN Monitor > IPsec > to see if IKEv2 VPN IP belongs to the LAN2 domain.
  • Zyxel_Jeff
    @ITB_Tony
  • ITB_Tony
    Thx works good =) , i have missed the "configuration Payload" option.
