So what Android App do I use to monitor my Zyxel USG40?
[Deleted User]
in Security
There are 10 Zyxel Apps. Nebula requires additional spending and a few others are for easy setup of this and that and other irrelevant things. Most are for other devices.
Let me guess, you need to license Nebula to do anything?
Oh... ERR_DEVICE_MODEL_NOT_SUPPORTED
Hi @SecCon,USG40 does not support to be monitored via App since it is not supported on Nebula cloud.You can consider USG FLEX series.0
Thanks but no thanks.
Hello @SecConYou could try using a network manager system that supports SNMP and Syslog, and then have an Android App to access that.- section 44.11 of the user guide available at ftp://ftp.zyxel.com/USG40/user_guide shows what I am suggesting.Paessler PRTG, see https://www.paessler.com/prtg , allows you to set-up as network manager. PRTG then has an Android App to access the network manager. I have tried it and it works.- I use my VMG1312-B10D router as the SNMP Agent.- I have PRTG on my LAN on a PC as network manager and then login to that using the PRTG Android App.I hope that this is helpful.Kind regards,Tony
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
