[NEBULA] Different DNS Servers per SSID
Remy
Remy Posts: 3 image  Freshman Member
edited April 2021 in Nebula
Can I specify different DNS Servers per SSID? So internal for employees and external for guests? We are also using the nebula gateway and switch
Thanks,
Remy
  • Remy
    Thanks a lot! What does this mean for the LAN1 group? There you cannot specify a VLAN.
    Regards,
    Remy
  • Zyxel_Dean
    Zyxel_Dean Posts: 237 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @Remy
    You have to click "Add" button on the interface panel to add VLAN.
    the Port Group of LAN1 and 2 are fixed, for additional VLAN interfaces you add, you can then choose the port group it belongs. Basically it is just telling which subnet interface are accessible on which ports of the gateway.
    -Dean
Nebula Tips & Tricks
