2 factor authentication with google authenticator
Zyxel_Can said:Hi @Motivio,
USG FLEX series with Google Auth 2FA already supported on Nebula.
You can use Secuextender IPSec VPN Client with Google 2FA for to your on cloud USG FLEX devices.
For ATP series on cloud, please kindly wait for Q4.
Hi @Zyxel_Can , could you please provide a direct link for documentation for this ?
The current demo here https://flex500.zyxel.com/ext-js/index.html#
only shows the old email or sms options :-/
Hello @CoreSGPlease refer to the attached documentation it has steps of how to configure 2FA on USG FLEX.
2 -
you can use 2fa with yubico key if you have one via your pc
Nebula_Chris - awsome, thanks !Nebula_Chris said:Hello @CoreSGPlease refer to the attached documentation it has steps of how to configure 2FA on USG FLEX.
And to use microsoft auth? I don't like google.
Hi, is this also valid for SSL VPN? Thank youBest regards0
Is there any update on when 2FA for VPN users using Google Auth (or MS Auth) will be supported on non-cloud devices? (Zyxel VPN100, in our case) Thank you, Best Regards
Dear ZyXEL Team,
For appliances with 4.65 firmware:
1/ It is possible to rename "Google Authenticator" to "OATH Token based on HOTP, OCRA, or TOTP" in Users/Group -> Edit user -> Two-factor Authentication -> Enable Two-Factor Authentication -> Two-factor Auth. Method?
Because there is not only the "Google Authenticator" application which supports it.
- https://i.ibb.co/ZXWbNTh/User-Group-Edit-user-Two-factor-Authentication-enabled.png
2/ It is possible to change:
- Enable Two-Factor Authentication for VPN Access -> Enable Two-factor Authentication for VPN Access
- Enable Two-Factor Authentication for Admin Access -> Enable Two-factor Authentication for Admin Access
- https://i.ibb.co/RbyBkY1/User-Group-Edit-user-Two-factor-Authentication-disabled.png
3/ There is a problem, in Object -> Auth. Method -> Two-factor Authentication -> Admin Access, choices are All/SMS/Email, there is not "OATH Token".
- https://i.ibb.co/w0DYh3K/Object-Auth-Method-Two-factor-Authentication-Admin-Access.png
4/ It is possible to add for VPN Access?
- https://i.ibb.co/9r033GR/Object-Auth-Method-Two-factor-Authentication-VPN-Access.png
Can you improve it?
Thanks in advance.
Zyxel_Chris said:Hello @CoreSGPlease refer to the attached documentation it has steps of how to configure 2FA on USG FLEX.
Hi Chris,Thank you very much for this description. I followed it and was able to add Authenticator support to my account - until I realized that this is only for IPSec VPN.Is it planned to enhance the 2FA of SSL VPN to use Authenticator support too?And if, do you have an idea in which timeframe?Thanks in advance for this information.Kind regards,Stefan0
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
ZCNE Certified
