Access point & Multi SSID
NWA1123-AC HD
Hi @Godinne
Welcome to Zyxel Community!
Multi SSIDs is a common feature supported on all Zyxel access point models.
The best choice for you to use lower price enjoying Wi-Fi is NWA1123ACv3
You could also consider NWA110AX which with the newer standard.
https://www.zyxel.com/products_services/802-11ax--WiFi-6--Dual-Radio-PoE-Access-Point-NWA110AX/
NWA1123-AC HD that @PeterUK suggested is also a good choice for starting
https://www.zyxel.com/products_services/802-11ac-Wave2-Dual-Radio-PoE-Access-Point-NWA1123-AC-HD/
If you require any further information, feel free to contact us.
Thank you.
Regards,
Bella
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
