zyxel VMG8623-T50B
SmartfaceNick
What is the latest firmware for the modem Zyxel VMG8623-T50B and where found to download?
Best Answers
I tried to search it, but didn't find it on the web site.
This model might only for ISP users, so there is no public firmware on the website.
If so, you might need to check the firmware with your ISP.1 -
thanks my friend for all the help you have given me all these days but i will change modems because i will also change provider.Kind regards, Nikos
The firmware is in ftp://ftp.zyxel.com/VMG8623-T50B/firmware/It is 5.50(ABPM.0)C0 version there.Kind regards,Tony
Unfortunately the link you are writing to me does not open.
I was able to download the upgrade file, but the update could not proceed by showing me on the screen that it failed to read the file .bin
Hello @SmartfaceNickDid you unzip the ZIP file into a folder with the .bin file in it?- sorry to ask the obvious question.When I upgraded my VMG1312-B10D last year, it was picky about which browser I used.- I had some success when I was doing the upgrade when using Firefox and then eventually MS Edge worked.So you might want to use Firefox as you browser when doing the upgrade.Are you able to post a picture of the error message that you are seeing please?Kind regards,Tony
Hello @SmartfaceNickThe user guide at https://service-provider.zyxel.com/global/en/products/dsl-cpes/vdsl/residential-iads/vmg8623-t50b under downloads might be helpful.- chapter 40 covers upgrading firmware.Kind regards,Tony
I have done everything you mention in your message. Unfortunately it shows me the message: "image uploading faailed."
Hello @SmartfaceNickThanks for your post.This sounds like figure 242 error message in the User Guide.- does it occur straightaway?What version of firmware is your router currently running?- it might be that the new firmware that is on ftp.zyxel.com is incompatible with what is already running.Kind regards,Tony
Model Name
VMG8623-T50B
Firmware Version
V5.50(ABRV.0)b6
It seems that the newer firmware is incompatible with the one you already have, because you have ABRV.0 branch and the one on the FTP is the ABPM.0 branch.
I think that this means that you need to talk please to the service provider who provided your device.
Kind regards, Tony
-- my own views, and not those of my employer. I also do not work for Zyxel.0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
