Is Possibile connect in a Second Tunnel VPN Fritz BOX from Home to USG60W
You can try these setting On Fritz Box.
(1) Pre-shared key
(2) USG Public IP address.
(3) IP subnet of USG.
On USG VPN Gateway:
(1) Entering correct Fritz Box public IP and Pre-Share Key.
(2) Setup AES-256/ SHA1 as algorithm.
On USG VPN Connection:
(1) Select VPN Gateway you created.
(2) Local Policy: Enter USG LAN IP subnet what you setup on Fritz Box setting.
(3) Remote policy: Enter Fritz Box LAN IP subnet.
(4) Setup AES-256 and SHA1 as algorithm.
Hello, thank you so much for you answeri try to do with a little file where is configuration upoload in format file .cfgin this case for a little time working well,but not have any opportunity to check with end customer, if the bridge is persistent or notgreat for your suggestbest regards0
- 588 USG FLEX H Series
- 477 News and Release
