NCC - SSID settings broken
Torben
Torben Posts: 2
edited June 2021 in Nebula
I have a very simple setup, with 9 NWA210 AP connectet to Nebula Control Center.
When i go to Access point > Configure > SSID settings, it shows the settings for the first SSID correct. Then when i try, in the dropdown, to select another SSID the client side code breaks, an in the console log, there is a "Must supply a value for form control with name: 'portGroup'" exception.
The result is that only few of the settings is updated on the page, to reflect the chosen SSID, and if you press save, you actually save settings from the first SSID, on the selected SSID.
In general, the interface seems broken, and often it just ends up unresponsive, and i have to reload the page.
Behavior is the same in both chrome and edge.
Are there any way to fix the above?
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @Torben
    Welcome to Zyxel community!
    Can you post a screenshot of exception page?
    We’d like to check the config of your SSID settings.
    Please enable the Zyxel support at Help > Support request > Invite Zyxel support as administrator, and provide the Org and Site name for us to check.
    Thank you.
    Regards,
    Bella
  • Torben
    Torben Posts: 2
    The exception in console log is
    Org: MM Vision A/S
    Site: Alfarvejen 57
    I have given support access.
  • Zyxel_Bella
    Hi @Torben
    Thanks for the information.
    We’ve confirmed the symptom in your site and will find the root cause asap.
    Will update this post if any update.
    Regards,
    Bella
  • Zyxel_Bella
    Hi @Torben,
    After checked, if user didn’t select USG model at USG FLEX > Monitor > USG FLEX will cause the exception issue due to the empty value.
    We’ve temporally assign a model name as the workaround for you to edit SSID without problem.
    We will implement the solution soon, thank you for your post of concerning the issue.
    Regards,
    Bella
Nebula Tips & Tricks
