IDP Whitelist for one IP
KITNIT
KITNIT Posts: 5 image  Freshman Member
Hey,
i have a site-to-site vpn between a USG60 and a ATP500. Everything works fine, except one small issue.
In one LAN behind the ATP500 is our Exchange Server. ScanToMail with our printers out of all LANs behind the ATP500 works. If i try ScanToMail from the LAN behind the USG60 it gets blocked by the IDP Filter of the ATP500:
"SSI=N [type=Sig(111118)] Ipswitch IMail Server SMTP Service Buffer-Overflow Action: Reject Receiver Severity: high"
As a workaround i whitelisted the Sig111118 in the IDP Settings. Is it possible to whitelist the Signature just for the IP of the ScanToMail printers and not in general?
Thanks for your help!
  • jasailafan
    jasailafan Posts: 193 image  Master Member
    I guess it's IDP signature problem. Got a similar issue recently that sending email is blocked by IDP Sig 111118: Ipswitch IMail Server SMTP Service Buffer-Overflow. Already reported the issue to zyxel support. Waiting for their update.
  • Zyxel_Emily
    We are aware of IDP signature issue and we are investigating it.
  • Mario
    Mario Posts: 111 image  Ally Member
    Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector Seventh Anniversary
    edited June 2021
    I'm also affected by this signature problem...
  • Zyxel_Emily
    The false positive for IDP Sig 111118: Ipswitch IMail Server SMTP Service Buffer-Overflow will be fixed in the latest IDP signature version 4.0.0.20210611.0 and 4.0.1.20210611.0.
    You can update IDP to this version and check if the issue is resolved.
  • Ghalan
    Ghalan Posts: 1 image  Freshman Member
    We had the same issue this week
    force update of IDP signature solves the issue.
    new version date is : 2021-06-11 03:10:00 (UTC+01:00)
    FYI : Default schedule for IDP Signature auto update is once a week (Sunday 1am)
