ATP800 - SSL VPN is slow
Antoine_Richez
Antoine_Richez Posts: 3 image  Freshman Member
Friend Collector Third Anniversary
Hey everyone,
I did the setup of a SSL VPN on our new ATP800 (setup was super fast and straightforward). The problem we're facing now is that we suffer from a really slow speed through the VPN.
We have a 500D/100U Mbps on site.
Through the VPN we barely have 600KB/s.
I tried to look on the net to search for a magic option hidden somewhere but didn't  really find anything yet.
I thank you all in advance.
Best regards,
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034 image  Zyxel Employee
    edited June 2021 Answer ✓
    @Antoine_Richez
    As current design, SSL VPN will have an disadvantage(in compare with L2TP) when it comes to throughput. It could be limited to 10-20Mbps.
    Also, RDP uses a lot of it's bandwidth for screen data and instruction transfer. It's not exactly designed as a file transfer protocol.
    To get the better performance, you could establish the L2TP with FTP download or use teamviewer as remote tool for downloading.
  • Zyxel_Charlie
    @Antoine_Richez
    Can I know what is the way you got the VPN performance, SMB, FTP or Http?
    I would like to establish the SSL VPN from my side, therefore can you private message the remote information to me?
  • Antoine_Richez
    @Zyxel_Charlie
    I've sent you a message with the corresponding informations.
    Have a nice day.
  • Zyxel_Charlie
    @Antoine_Richez
    Thanks for your information.
    If possible, I would like to know the RDP information of this scenario for check further.
  • Mario
    Mario Posts: 111 image  Ally Member
    Zyxel Certified Network Engineer Level 1 - Security First Comment Friend Collector Seventh Anniversary
    Did you get an solution? Please keep us also up to date.
    I think it's a generic problem, the speed of the SSL VPN is bad.
    See in the Ideas section, and please upvote the Wirequrard request.
    Mario
  • Zyxel_Charlie
    @Antoine_Richez
  • Mario
    >As current design, SSL VPN will have an disadvantage(in compare with L2TP) when it comes to >throughput. It could be limited to 10-20Mbp
    Is it on the roadmap to fix this design issue?
    Openvpn or Wireguadr are known solutions to solve such problems ;)
