How Do I Manage Or Delete Tags In NCC
businessuer
businessuer Posts: 134 image  Ally Member
I accidentally created a wrong tag in the NCC.
I dont plan to use it anymore.
How do I see all my tags and delete the ones I dont need?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,618 image  Zyxel Employee
    Hi @businessuer,
    Good day.
    According to your requirement, you can see all your "site tag" on organization-wide >overview.
    You can select the site you want to remove tag and click the tag bottom to remove.
    In addition, you can remove device tag on device monitor list(like Menu>switch>Monitor>switch)
    You can select the device you want to remove tag and click the tag bottom to remove.
    Hope it helps.
    Zyxel Melen
  • businessuer
    Yes I can remove the device tag.
    But I want to remove the device tags that I am not using.
    Remove from the database.
  • Zyxel_Melen
    Hi @businessuer,
    I have done a local test.
    I removed all tags from device, and the device tag disappeared on NCC.
    You may try to remove all tags from device and achieve your requirement.
    Zyxel Melen
  • businessuer
    It doesnt solve the problem.
    The tag is still in the database.
  • Zyxel_Melen
    Hi @businessuer,
    May you enable Zyxle support and provide your org name?
    Zyxel Melen
Nebula Tips & Tricks
