are there any public HTTP RESTful APIs for the Nebula portal ?
Hi @RTH10 ,
I will PM you for more detail information.
Please check your Inbox of Zyxel community or your email mailbox.
Thanks.
Hi @Zyxel_Jason,
Iam also interested in testing or using an API for Nebula. I'm currently working on my Home automation and I use Zyxel Network Products, wich will be great if an API exist.
(GS1920-24HP , 2x NWA210AX)
Thanks a lot.0 -
Hi @x3n0,
Now we only have few API for project engagement, not in general availability yet.
We are working on the Open API by phase approach per customer and market needs, for sure it is limited by our resources until the business priority getting more clear.
May you share what information you would like to have the most via API for Nebula in your scenario?
For example: The online/offline status of Switch or AP.
Thanks.
2 -
Hi @Zyxel_Jason,
Thank you for your answer.
It would be great to have on the AP the possibility to see witch client is online and to switch on and off SSID´s over the API.
At the Switch it would be good if there is the possibility to switch on or off poe ports over the API (to switch off AP´s completely , or reboot poe devices). If there is the possibility it would also be nice to see stats at the API ( power on each poe port, traffic etc.)
Thanks a lot
x3n00 -
Thanks for your feedback.In the current roadmap, the public API in first phase will let user collect the status and some statistics from Nebula device.We will still put those configure-related features you mentioned in our future roadmap for public API.
Please note that the public API will be a NCC Pro Pack feature when it is released.0 -
I'm doing home automation as well. I have a GS-1910-24HP and as such it has POE. What I would like to see in the API is the ability to turn the POE on/off on a per port basis.I use the POE ports to power my Amazon Fire tablets which serve as dashboards. Over a period of time if one does not remove the charging power it will cause battery failure and damage to the tablets. My other project involves POE lighting and since I have 24 ports available to me this is a natural option to run those.Thanks.Glenn...0
Hi @Stampeder,
Like I mentioned above, configure-related feature is in our future roadmap.
But for you scenario, have you tried to configure PoE schedule for Switch ports on Nebula CC?
User can create PoE schedule profile at Switch > Configure > PoE schedules and apply it to ports.
After creating profile, the user can go to Switch > Configure > Switch ports, select ports and apply the PoE schedule.
In this example above, the ports which are applied New Schedule will only enable PoE at 8:00~20:00 everyday.
Hope it helps.
dears, is it possible to do it ( switch on and off) POE via nebula just for one or specific group of Ports? And is it included in basic license?Looking for a gigabit switch 8 ports poe+ Can you suggest me one?Thank you0
- 438 Beta Program
- 189 Nebula Ideas
- 6.2K Security
- 463 USG FLEX H Series
- 304 Security Ideas
- 81 Switch Ideas
- 280 Service & License
- 440 News and Release
- 4.3K FAQ
- 91 Security Highlight
