Unable to restore factory defaults on XGS1930-28
Bartestro
Bartestro Posts: 1 image  Freshman Member
edited August 2022 in Switch
I've done almost everything.
Reseted with factory defaults with 3,4, 10 seconds.
Nothing helped, it seems switch is not resetting to default values.
Tryied with myZexel. I receive message device already registered.
Where I should go from here to recover access to my device?
  • Zyxel_Jason
    Zyxel_Jason Posts: 428 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @Bartestro,
    Welcome to Zyxel community!
    Since there are Reset and Restore button in the front panel of XGS1930, please help to check if you press "Restore" button for over 7 seconds to do the factory default.
    Hope it helps.
    Jason
