WiFi Controller - From USG310 to ATP500 (cannot move APs)
Hi @CSCComo
Welcome to Zyxel community!
Can you shutdown USG shutdown or make it outside the topology and re-connect APs to ATP500 wait for a while?
If the AP and ATP500 are on the same subnet, the AP will automatically detect and connect to ATP500.
After AP successfully communicated to ATP500, the AP appears in the AP List on MONITOR > Wireless > AP Information page.
Then you have to select APs and click “+” button to add APs to the managed AP list.
Regards,
Bella
Hi. We completly replaced the usg with atp in the rack, but after half an hour, we couldn't find any AP, so we made some try with the old one. We didn't try to restart APs, but we resetted one while it was connected to the new firewall
Hi @Cava
Because CAPWAP has four types to do auto discovery, we’d like to know if you’ve set DHCP Option 138 or other methods instead of broadcast.
Can you apply this command by ssh into AP to check the discovery type and ac-ip:
Router: show capwap ap info
Controller only replied the CAPWAP packet when receives from AP.
The ac-ip must be the IP of ATP500 or AP will not send CAPWAP packet to ATP500.
Regards,
Bella
Sorry for 2 accounts. We both are working together. In the old firewall there is nothing configured for this. I'm in place now. 0 WiFi.... Now I shutdown first floor to check but nothing works0
Ac-ip 192.168.2.1 (I changed this on old fw to .20.1 and put .2.1 on new fw.... so probably that's the problem ...)
Fallback disableFB into 30
Discovery type DHCPSm state disc2Msg-buf-usage 0/10
Capwap version 10003
Radio number 1/4
BSS number 8/8
Iana Id 037a0 -
Firewall 5.00 ABFU.2Access point 5.10 AAID.8 v1.26
Now I'm trying to bypass a gs1900-8hp switch0 -
I can't find on AP the mgnt mode menu0
We found the problem l. I don't know how were configured the switches (no vlan on firewall). We resettled them and so everything gone right0
Hi @CSCComo
When change the settings of ac-ip or deploy a new device/topology, ensure the corresponding interfaces had been configured well is the way to prevent devices loss communication.
Thanks for the update. It’s nice to hear your problem resolved.
If you require any further information, feel free to contact us.
Regards,
Bella
- 431 Beta Program
- 2.6K Nebula
- 169 Nebula Ideas
- 6K Security
- 368 USG FLEX H Series
- 294 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 265 Service & License
- 409 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
