Error Zyxel Service is terminated
  • Anders
    Anders Posts: 1  Freshman Member
    Same sh.. happened to me right now - what is the fix?
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    @Anders
    What is your device model? I will send you the firmware via private message.
    Charlie
  • frerealexis
    frerealexis Posts: 21  Freshman Member
    I'm having the same type of problems with USG210 running on FW4.35.
  • alexey
    alexey Posts: 188  Master Member
    Again on new fw? Great...
    Zyxel. Zyxel never changes...
  • frerealexis
    YES, on FW 4.35. And rebooting doesn't solve anything. In fact the reboot does not work. After rebooting I had to unplug the device. And this morning, I have once again the same message.
  • frerealexis
    I have disactivated all authentification rules and the USG sees to be back to normal.
  • frerealexis
    Finally, it seems that the problem comes from FQDN groups for which I created security rules. After disactivating these rules, the message ERROR ZYXEL SERVICE IS TERMINATED does not appear and CPU is back to normal.
  • AntonProf
    AntonProf Posts: 1  Freshman Member
    iv got the same problem now on my zywall310. restart is not working
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,397  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @AntonProf
    Which firmware is working on your device?
    Can you upgrade to 4.38 firmware first and check if it help in your case ?
  • Matias
    Matias Posts: 1
    Hi Anton, I have the same issue with my zywall310. Do you have some news? Could you solve the problem?
    How can I upgrade/downgrade it if I get this message?
    Thank you!
