Own certificate on GS1920 or GS1900-10HP
  • switch
    switch Posts: 2 image  Freshman Member
    Well, it is possible. Too bad, this has to be done over telnet (i.e unsecured communication device).
    Hope official way to perform this change would be possible at some point.
  • Zyxel_Ryan
    Zyxel_Ryan Posts: 72 image  Zyxel Employee
    First Answer First Comment Friend Collector
    Hi @switch
    Thanks for your sharing!
    We have noticed that there might be method of making certificate as you did on GS1900.
    Due to this is not a formal feature on GS1900, we can not guarantee the performance of it.
    Therefore, we do not recommend users to use it.
    As mentioned in the previous discussion, this feature will be added in Zyxel switch except for GS1900 series because it is an entry level managed switch.
    Ryan
  • Francisco
    Francisco Posts: 6 image  Freshman Member
    Hello there,
    What is the news on this? When can one import SSL-certificates on Zyxel Switches?
    On what Firmware version will that be (release when?) and on what Switch series will that be feature be?
    cheers,
    Francisco
  • Zyxel_JonasTan
    Zyxel_JonasTan Posts: 98 image  Zyxel Employee
    Hello @Francisco,
    The import certificate feature will be launch on XGS4600-32/32F (firmware version 4.60) first this coming December.
    Zyxel_Jonas
  • switch
    edited January 2019
    Why exclude GS1900? Importing certificate worked perfectly fine.
    Actually, since the method I'm using still works -- I'm happy. DO NOT TOUCH :angry:
  • eddeig
    eddeig Posts: 9 image  Freshman Member
    So, since it is almost the end of 2019, how can I install an certificate on an XGS2210-28HP?
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 282 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    Hi @eddeig
    For XGS2210 series, the feature will be enhanced in the upcoming firmware 4.70 which is scheduled at 2020 Q3Q4.
    Zyxel_Lucious
  • Francisco
    What is the news on this? when will 4.70 be available and will we be able to import certificates then?
  • Zyxel_Derrick
    Zyxel_Derrick Posts: 126 image  Zyxel Employee
    edited October 2020
    Hi @Francisco
    We have a light change to the release schedule of XGS2210 version 4.70.
    It will be released in 2021 Q1.
    Best regards,
    Zyxel_Derrick
  • Francisco
    It's July 13th 2021... So we are in Q3, right?
    When will we finally be able to import certificates?
    This is very annoying and most UNPROFESSIONAL!
    Francisco
