Unable To Fix DNS Server Not-Responding Issue
william_gra
william_gra Posts: 2 image  Freshman Member
Hello friends. I have not been able to solve a computer’s internet problem for the last 2 days, that is, every time I try to connect the Internet to my computer, the DNS server not responding, the error is showing. I am currently using the internet from my mobile phone. This is why I’m having so much trouble using my computer. Guys, I don’t know why this is happening and how to fix this issue. Please help me to solve the problem. Any help will be appreciated.
    Maybe your ISP DNS is the problem? Change DNS on the router to like 1.1.1.1, 8.8.8.8 or 9.9.9.9 and reconnect to the router to use them DNS IP's
  • Podo
    Podo Posts: 28 image  Freshman Member
    What is your router's model?
    You can configure DNS server as PeterUK said
  • william_gra
    Thanks for replying. I have applied the processes you have given before, but it has not been resolved.
  • Dennisscannell
    Dennisscannell Posts: 1 image  Freshman Member
    Hello. I have a solution for you. Just follow the article. Best of luck.
