How can I do this? I think it's NAT.
10.0.0.201 is within Network A (10.0.0.0/24 ) so it will not go over the WAN to the WAN of Network B (192.168.1.0/24).
Their might be a another way if you can send out a UDP packet to 10.0.0.xxx to a virtual interface on 10.0.0.0/24 say 10.0.0.254 you then do a NAT rule to the WAN of Network B and routing rule to SNAT from Network A WAN of the traffic.
Then Network B NAT to 192.168.1.7
Yeah, for reasons, the packet is hard-coded to go to 10.0.0.201. I was thinking of a virtual server/interface that then translated to 192.168.1.7 and sent through the tunnel but somehow, I am just not sure I am doing it right.0
The virtual interface way would work as long as you don't have a device with 10.0.0.201
So Network A virtual interface 10.0.0.201 on 10.0.0.0/24
NAT
incoming interface like LAN1
external IP User Defined 10.0.0.201
internal IP User Defined the WAN of Network B
port mapping the port its sending out to.
Routing
incoming interface
member like LAN1
service the port 10.0.0.201 is sending
next-hop
type interface
interface like WAN1
source network address translation outgoing-interface
on Network B
NAT
incoming interface like WAN1
external IP WAN1 address object interface
internal IP User Defined 192.168.1.7
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
