How Do I Manage Or Delete Tags In NCC
businessuer
in Nebula
I accidentally created a wrong tag in the NCC.
I dont plan to use it anymore.
How do I see all my tags and delete the ones I dont need?
Hi @businessuer,
Good day.
According to your requirement, you can see all your "site tag" on organization-wide >overview.
You can select the site you want to remove tag and click the tag bottom to remove.
In addition, you can remove device tag on device monitor list(like Menu>switch>Monitor>switch)
You can select the device you want to remove tag and click the tag bottom to remove.
Hope it helps.Zyxel Melen0 -
Yes I can remove the device tag.
But I want to remove the device tags that I am not using.
Remove from the database.0 -
Hi @businessuer,
I have done a local test.
I removed all tags from device, and the device tag disappeared on NCC.
You may try to remove all tags from device and achieve your requirement.
Zyxel Melen0 -
It doesnt solve the problem.
The tag is still in the database.0 -
- 441 Beta Program
- 532 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 293 Service & License
- 461 News and Release
