I can't log into my Zyxel router
Parviz
I've tried to log in to the router by 192.168.1.254 as it says in CMD ipcofig. I get the log in window but whatever combination of login/password I use I can't log in. admin/1234 doesn't work. I’ve tried to reset the device still no luck. This is important as I can't change the wi-fi password
I’m connected to P-2812HNU-F1 vT
Thanks for advises
Thanks for advises
Hello @ParvizYou probably need to do a hard reset in order to get back in, and that will change the WiFi password as well.You will lose all of your router configuration I think.https://www.router-reset.com/info/ZyXEL/P-2812HNU-F1 talks about how to do a hard reset.Kind regards,Tony
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 498 USG FLEX H Series
- 323 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
