SD WAN - Setup Router Configuration
Orbital
Orbital Posts: 2 image  Freshman Member
First Anniversary
Hi we have two offices one in LA on in London.
I ahve set up the SD-WAN cloud stuff and have the units display there.
If however we reset the uinits to factory default surely we don't have to set up all the firewall's again ?
Can we migrate the config somehow ?
  • Zyxel_Stanley
    Hi @Orbital
    After reset your device, then device configuration will become to standalone.
    It means you have to re-configure device if you would like keep it as standalone mode.
    If you would like turn back device as SDWAN mode, then you have to re-ZTP again.
    Before ZTP, you have to un-link your device from your site first.
    The old configuration will exist on cloud, device will download configuration from O
    rchestrator after ZTP completely.
