[NEBULA] What are other options for switch ports alert?
Iwannaquitthegym
Hi community,
When you configure the Alert settings, specifically for the switch ports, there's a drop down menu that only contains the option "Any switch port", what else can I configure here and how?
Hi there Iwannaquitthegym,
You can specify the ports by adding tags to the port, goto Switch> configure > Switch Ports
Check the ports you want then press Tag, and add a tag to the ports.
Then you should be able to see it in the alert drop down menu!
6
6 -
Nice! Thanks for your help0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
