SFP P1 port does not work Lind Down
Hello
The SFP port does not work on my Zywall USG Flex 100W I have an Amazon ZyXEL SFP-1000T 1000Mbit / s SFP network transceiver module - network transceiver modules (1000 Mbit / s, SFP, IEEE 802.3z, 100 m, 0 -70 ° C, -40-85 ° C) and is also from Zyxel.
On the hardware itself, the SFP P1 port lights up and the "Ethernet" configuration is SFP activated (yellow lamp). but nevertheless it shows me under port configuration that the link is down. even a factory reset was unsuccessful, and changing the name from SFP to WAN2 did not work either. Why is it that the port does not work
Best Answers
Maybe the module is faulty?
Are you able to test in a switch?0 -
Hello many thanks
this procedure worked, the SFP module works properly and Zyxel modules do not work either.
I just hope that in the future this will also work from the beginning on the other USG Flex 100w models that are purchased, without having to install the boot module.
SFP P1 Port does not work Link Down0
Hello Unfortunately no I don't have a switch with an SFP slot. On the USG Flex 100W, the SFP LED lights up and only flashes from time to time under "Configuration" -> "Port" -> Port configuration, it still shows Link Down and the Zywall USG Flex 100w has been new and bought for 3 months do not think that the SFP slot is defective, an SFP module by Delock SFP-1000T does not work either.
Hi @jauxi1981,Welcome to Zyxel community.
It could be related to device boot module. Can you take a screenshot of boot module version and sent me via private message.How to check boot module:Router# psmRouter(psm)# atsh0 -
Hellohere the excerpt from psm atshRouter # psmRouter (psm) # atshKernel version: V3.10.87 | 2021-07-04 03:04:51ZLD Version: V5.02 (ABWC.0) | 2021-07-04 03:43:00BootModule Version: V1.18 | Sep 27 2019 10:28:46Vendor Name: Zyxel Communications Corp.Product Model: USG FLEX 100WSystem Type: 10First MAC Address: XXXXXXXXXXXXLast MAC Address: XXXXXXXXXXXXMAC Quantity: 8Default Country Code: E1Boot Module Debug Flag: 00Serial Number: S202L29140080Baud rate: 115200 bpsBM checksum: 085C9731Core checksum: 9B2C42F4Conf checksum: 68AD63B3SNMP MIB level & OID: 060102030405060708091011121314151617181920Main Feature Bit: 00Other Feature Bits:66 E1 00 00 00 00 00 00-00 00 00 00 00 00 00 0008 00 00 00 00 00 00 00-00 00 00 00 00 00Router (psm) #Router (psm) #Many Thanks0
Hello Here is the version of the firmwareRouter> show versionZyxel Communications Corp.image number model firmware version build date boot status===============================================================================1 USG FLEX 100W V5.01(ABWC.0) 2021-06-26 02:25:38 Standby2 USG FLEX 100W V5.02(ABWC.0) 2021-07-04 03:43:00 RunningRouter>
Best regards0 -
Hello many thanks
Was there a resolution on this?0
Hi @EliteITGuy,
- 588 USG FLEX H Series
- 477 News and Release
