NSG100 least load first
Fabry69
Fabry69 Posts: 1 image  Freshman Member
edited July 2021 in Nebula
good morning,
with this load balancing algorithm, is there any possibility to route the traffic of an specific ip of the LAN network only on Wan1?
Thank you
    PeterUK Posts: 4,435 image  Guru Member
    You should be able to do that with a routing rule.
Nebula Tips & Tricks
