set custom SSL certificate on 2FA landing page (port 8008)
Hi, we have installed (imported) the company wildcard SSL on the Zywall. I have attached it to all the sites where possible in the Zywall 310. (see attached picture).
There is also a hostname in DNS to office.company.com that resolves to the external IP address, so all links are running fine internal and external without questions about unsafe pages etc. The only page that still gives a message that the connection is not private and uses the default SSL certificate is the landing page for the link in an email that is send to a SSL-VPN user which has two factor authentication enabled. In Zywall it is called: Authorize Link URL Address (Object-->Auth.Method -->Two-factor Authentication -->VPN Access). How and where do I change the certificate on that lading page, i can't find a place in the GUI to change it?
Ah great, thanks for the link! This is what i needed.0
- 603 USG FLEX H Series
- 480 News and Release
