GS-108B v3 and gigabit not working
Franco_Marconi
Franco_Marconi Posts: 2
Second Anniversary
edited August 2022 in Switch
This is my problem:
Router with speed 1Gbps --> switch D-link --> PC goes to 1Gbps
same router --> switch D-link --> switch zyxel GS-108B v3 --> same PC with same cable goes to 100M/100M
Any idea?
Best Answers
    PeterUK Posts: 3,995  Guru Member
    check your NIC has EEE Energy Efficient Ethernet or green power off
  • Zyxel_Adam
    Zyxel_Adam Posts: 429  Zyxel Employee
    Zyxel Certified Network Administrator - Nebula 25 Answers First Comment Friend Collector
    edited July 2021 Answer ✓
    Hi @Franco_Marconi,
    Welcome to Zyxel Community!
    As @PeterUK mentions that you may check your NIC of PC/laptop to see if EEE or GreenEthernet feature is enabled.
    If so, our switch lower down your link speed for saving power.
    To resolve the issue, please disable it on NIC of your PC/laptop.
    Let me know if you have any concern.
    Adam
  • Zyxel_Adam
    Hi @Franco_Marconi,
    Adam
  • Thank you both :-)
    problem solved and shame on me for not checking that
    Good to know it works at 1Gb now
    The speed link likely downgraded due to the quality of the cable or length.
