GS-108B v3 and gigabit not working
Franco_Marconi
This is my problem:
Router with speed 1Gbps --> switch D-link --> PC goes to 1Gbps
same router --> switch D-link --> switch zyxel GS-108B v3 --> same PC with same cable goes to 100M/100M
Any idea?
Any idea?
Best Answers
check your NIC has EEE Energy Efficient Ethernet or green power off0
Hi @Franco_Marconi,
Welcome to Zyxel Community!
As @PeterUK mentions that you may check your NIC of PC/laptop to see if EEE or GreenEthernet feature is enabled.
If so, our switch lower down your link speed for saving power.
To resolve the issue, please disable it on NIC of your PC/laptop.
Let me know if you have any concern.
Adam
Hi @Franco_Marconi,
Adam
Thank you both :-)
problem solved and shame on me for not checking that0 -
Good to know it works at 1Gb now
The speed link likely downgraded due to the quality of the cable or length.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
