L2TP VPN setup on USG60 via Wizard
Dear Sir,
I followed the Quick Setup (via Wizard) instruction of this link: https://community.zyxel.com/en/discussion/4532/how-to-setup-l2tp-vpn
Windows PC client end with relevant IPSec services up and running, encountered error 789 when connecting to L2TP channel.
Any advice from the support for me?
L2TP error 789 is: Security layer encountered error.
You can try to check IKE and AuthIP IPSec keying modules is enabled on your PC. You can restart it and and check if any help.
Sir, both were started and running. See attached screen shot (Word Doc).
Should support require my config file, I can upload it for your review.
Hi, Stanley. I will send it to you by tomorrow when I am on site. Tks in anticipation.0
Can you provide me your private email address?0
Hi, Stanley. Just sent out the document via the MAIL icon (I believed it was the top right hand corner, envelope icon).0
Stanley, enabled a Policy Rule for TrustedIP as advised this morning. Appreciate your taking a peek at our USG60 configuration.
Hi @peterpoon
The issue is come from default policy control rules are deactivated.From WAN to ZyWALL, Service: IKE/ESP/AH/NATT. Action: allow.These rules are for VPN connection. After enabling them, L2TP VPN tunnel is working.
From IPSec to ZyWALL, Service: any, Action: allow.
From IPsec to any. Service: any. Action: allow.0
- 415 Beta Program
- 2.5K Nebula
- 155 Nebula Ideas
- 105 Nebula Status and Incidents
- 5.9K Security
- 319 USG FLEX H Series
- 286 Security Ideas
- 1.5K Switch
- 1.1K Wireless
- 42 Wireless Ideas
- 6.6K Consumer Product
- 256 Service & License
- 398 News and Release
- 86 Security Advisories
- 3.7K FAQ
- 78 Security Highlight
