VPN traffic in only 1 direction
I have 2 sites connected via site to site VPN but I am only able to send traffic in 1 direction between sites. It connects so I know it's not a VPN issue. The site that cannot send has a new router so I don't think it's a stray rule somewhere but I am at a loss. Any ideas what I should be looking for?
Do both ends have different LAN subnets?
If you ping from one end do your see any blocked traffic in the logs?0 -
While doing further troubleshooting I discovered that something was wrong with the Firewall on the remote system. I managed to screw it up while testing to the point of HW reset. I had an older config that works so I am good.
@PeterC
Everything is fine now?
As PeterUK mentioned, you may make sure both ends are located in different subnet.
You can do the packet capture of wan and lan on both device or on the log page to see where block the traffic
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
