how to create a vpn on ZYXEL usg20w
According to your needs, you can refer to the below tutorials of L2TP and SSL VPN.
L2TP VPN tutorial:
https://community.zyxel.com/en/discussion/4532/how-to-setup-l2tp-vpn#latest
SSL VPN tutorial:
Thanks.
do i necessarily need to use SECUEXTENDER software? I have tried only setting up a remote connection on windows 10 but it doesn't work, it says "tunnel attempt could not be done" or similar ( i translate it from italian language)0
hello
while i could configure ssl and it works..there is no way to have l2tp working. I follow all the steps, but seems someting is missing. When i ry to connect from my pc it seems that it does not even reach the gateway, i don't see any event in the router log also..can you please more specific? thank you0 -
How about using the mobile devices to build up the L2TP tunnel? If the mobile devices can build L2TP VPN successful, you need to check on your PC’s routing table or try to remove the VPN profile on you PC and rebuild it.
If the mobile device doesn’t work, too. You may need to check on the log and share it with us in private message.
i don't know how to create vpn tunnel from a mobile phone. Anyway when trying from Pc i don't see anything in the log0
@stefanocps Not sure which mobile device you own but I ever established L2TP VPN successfully via my iphone. Maybe you can refer the tutorial of "Setup L2TP configuration on IOS" or "Setup L2TP configuration on Android" which @Zyxel_Jeff provided previously https://community.zyxel.com/en/discussion/4532/how-to-setup-l2tp-vpn#latest0
canceled
NEWS: i have been able to connect through mobile phone. So what's wrong on pc?0
You can refer to this discussion: https://community.zyxel.com/en/discussion/3567/the-l2tp-connection-attempt-failed
Please check the windows service of “IKE and AuthIP IPsec Keying Module” if been enable, if so its status will show started.
BTW, if you had executed another VPN client software, please stop it and re-start the “IKE and AuthIP IPsec Keying Module” service again. Please refer to this KB link: https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=018073&lang=EN0 -
that service is regularly running. Ypu linked me a topic where the solution is suggeste din adding some rules in router's firewall. But if the vpn works from mobile, i don't think it is needed adding those rule in firewall..isnt'it?0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
