WAN PORT CANNOT USE 1000GB
i have an USG310 (4.31(AAPJ.0)) and wanna to use the Port2 to connect with ISP. and the ISP offered is 1GB network to us. i plugged the Cat5e cable to the USG310, and got the status 100M/Full only. and try to perform speedtest, the output is 9x MB. I plugged the cable to my laptop, it's show 1GB. and the speedtest is 4xxMB.
i try to replace cable, and change port, the status still 100M/Full. and i try cli command, it seem only allow me to change the speed to 10 or 100.
Is there any solution on the above issue ?
Thanks in advance.
Thanks in advance.
Could be a link issue a workaround is to get a 5 port 1Gb switch and connect that in between the connection.
Can you give the modem info being used.
Hi @JOEY,
It looks like some kind of auto negotiation interoperability with ISP router .
Can you put a Gigabit switch and try it again?
thanks, i will try it tonight0
@Zyxel_Cooldia
i try to use plug a 1gb switch on that port, and the result is the same as direct plug the isp eth cable.
@PeterUK
the model of the modem is: Huawei - EchoLife HG8040H GPON terminal0 -
i used other router (zyxel USG 1000) to test, and got the status is 1000M/Full.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
