Cross-LAN to share a single printer/scan
tyler779
tyler779 Posts: 2
Fifth Anniversary
image  Freshman Member
I need to share a single printer in 2 different LAN created under the zyxel usg20-vpn.
The printer is on LAN1 with 192.168.61.163 IP ADDRESS.
I create the object "PRINTER, host, 192.168.61.163"
I make a secury policy:
from lan2
to lan1,
source ANY
destinantion PRINTER
but it do not ping and do not work from LAN2.
why?
thanks a lot for your help
    PeterUK Posts: 4,798
    image  Guru Member
    edited July 2021
    Are you pinging by IP?
    Do you have Use IPv4 Policy Route to Overwrite Direct Route checked in routing? uncheck it
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,591
    image  Zyxel Employee
    Welcome to Zyxel Community.  :)
    Did you set up gateway on printer?
    Without gateway setting on printer, it is unable to routing back from lan1 to lan2.
  • tyler779
    tyler779 Posts: 2
    Fifth Anniversary
    I tried to set gateway on printer.nothing it do not work.
    I cannot ping the printer from lan2
    there is an user manual where to find some screenshoots that show how to do?
    thanks.
  • mMontana
    mMontana Posts: 1,512
    image  Guru Member
    Whoa... kudos and (healthy) envy for such a so big screen, dude :-)
    Another way might be a 1:1 nat among networks...
  • lalaland
    lalaland Posts: 91
    First Answer First Comment Friend Collector Sixth Anniversary
    image  Ally Member
    Can you see ICMP request & reply on Lan 2 interface?
    Packet capture:
    Router> packet-trace interface lan2 extension-filter icmp
