Flex200 & Nebula
CRU_Technologies
in Nebula
The user guide for the Flex200 seems to be in none Nebula mode.
Is there a guide for Flex200 Nebula Mode?
As 'obviously' the configuration options for direct management seem to far outway the NCC configuration options.
Can I configure it in none NCC mode, then put it back into NCC mode?
Hi @CRU_Technologies,
You may check the NCC user guide for all Nebula features on NCC.
(Include AP, Switch, Security gateway, USG FLEX and NCC)
Since it will be updated after we release new phase for Nebula CC, you may find the link at Help > Online documents page.
For your question that move USG FLEX to Nebula, please note that USG FLEX will need to reset before doing ZTP process.
You may refer to this link for more details.
Hope it helps.Jason0 -
OK thanks.I don't seem to be able to create a service range or a group?So where normally I would create a service and can put a start port and end port, I don't seem to be able to do that?0
If you would like to configure multiple ports for security policy, you may add it in the Dst Port column directly.
Here is an example for you to reference.
Hope it helps.
Jason0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
