Port Forwarding but own IP device not shown (Zyxel ARMOR G5 AX6000 NBG7815)
cuterex
in Home Router
I bought and set up the router. However, my servers are not recognized in the network. But I can access it. Now I would like to do a port forwarding. However, you can only select the devices that are displayed under "device list". My server and my Synology Nas are not listed there. How can I still do port forwarding on these devices?
Well I call that a oversight bug how did Zyxel not think of this problem when its been years and years of routers needing you to put a IP in for Port Forwarding. Is their no user defined option? Their needs to be.
Is your your server and Synology Nas set to DHCP? What if you add a a static DHCP in LAN and see if that lets you Port Forward.
The problem has already been solved. But thanks for the answer.
- 241 Nebula Ideas
- 6.8K Security
- 755 USG FLEX H Series
- 379 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 320 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
