Securextender Mac BigSur V1.2.1 installed - problem with server port definition
on my USG I've changed the default SSLVPN port to 45007 In the Securextender connection definition I'm therefore adding the firewall IP WAN address in the format xxx.xxx.xxx.xxx:45007 and than click SAVE button. If I re-edit the just saved entry I found an extra :14400 being added resulting in xxx.xxx.xxx.xxx:45007:14400 which of course is not landing anywhere on connecting. If I delete and re-save, the sw is re-adding the :14400 suffix.
The result is that I can't no longer connect. Please not the other Securextender clients we do have in the company's older Macs, works perfectly with the xxx.xxx.xxx.xxx:45007 syntax (no suffix added on save).
Is it normal?
Is it normal?
Thanks for the clarification, but since I've enabled the two-factor authorization for VPN, all of the Mac Securextender clients do not connect any longer. The few external Windows ones do work (the email with link to authorize the connection is received and once selected, the connection is enabled. Working fine the same through LPT2 connection.) On the Securextender on MACs the connection timesout quickly and no email authorization is received. Therefore I was thinking that was the issue... It sounds like the problem is elsewhere....
Hi @maurpra,Please send me the remote access of your USG and one SSL VPN account/password in private message.0
Thanks for the support. I managed to get it working again with the two factor authorization. Something corrupted on install most likely. After de-installing and cleaning install residual with an utility, reinstalling the latest version 1.2.1 now the connection request is going out again.....0
Which utility did you used?
CleanMyMac X which found residual files to be eliminated...0
- 441 Beta Program
- 292 Service & License
