USG60W – Maintenance – Packet Capture – ftp
Ikarus
Ikarus Posts: 20 image  Freshman Member
I would like to capture packets and save them on an external destination.
If I activate the ftp option I get an error in the “Captured Packet Files” field. If I keep the default 10 I should enter 0. And if I enter 0 the requested minimum number is 1.
So, the question is, does the ftp option work at all?
Ikarus
  • Zyxel_Stanley
    Hi @Ikarus
    The notification means your system without enough storage to save file.
    But you still can ignore notification and save capture packets to USB storage or external FTP server.
    Is any problem to save your file to external FTP server?
    You may take a screenshot of your test result or drop private message to me for further check. :)
